I want to know how much time has elapsed since a certain event, and I do not want to use any external timers. It seems logical to reset an internal timer whenever the event occurs (using an interrupt). Unfortunately, as far as I can tell, millis() and micros() cannot be manually reset. Obviously, I could save a time stamp whenever the event occurs; however, I want to avoid overflow problems (micros() will overflow every ~71 minutes, and millis() will overflow every ~50 days).
Is there a way to manually reset these built-in counters? If not, how can I manage the overflow?
rebatoma
  • 559
  • 22
pseudoeuclidean
  • 131
millis() and micros() overflow periodically. However, this is not a problem: as long as you compare durations instead of timestamps you can forget about the overflows.
The liked answer also gives the trick for resetting millis(). Can be handy for testing purposes, but you do not need this to handle the millis() rollover problem. Notice that there is no clean way to reset micros(): it relies on a static variable, i.e. a variable private to the file defining it.
Edgar Bonet
  • 45,094
  • 81
Overflow is never really an issue if you always calculate time difference. (Unless the time difference is more that 50 days.)
unsigned long previousTime = millis();
... wait for some event to happen ...
unsigned long elapsedTime =  millis() - previousTime;
Even if previousTime was before the overflow, and millis() is after the overflow (so essentially millis()<previousTime), elapsedTime will still be the correct value.
This is because the calculation itself will also overflow. Since millis()<previousTime, the result would be negative, but the type of the variable is unsigned, so it wraps around. I hope that makes sense.
Just don't ever do something like if( millis() > (previousTime+1000) )
If you still want to reset millis, you can use the following:
extern volatile unsigned long timer0_millis;
unsigned long new_value = 0;
void setup(){
  //Setup stuff
void loop(){
  //Do stuff
  //Change Millis
  setMillis(new_value);
void setMillis(unsigned long new_millis){
  uint8_t oldSREG = SREG;
  cli();
  timer0_millis = new_millis;
  SREG = oldSREG;
Gerben
  • 11,332
  • 22
  • 34
No it doesn't. You don't reset your clock to 00:00 when you put a cake in the oven do you?
What you do is note the time. Then periodically you subtract the start time from the current time, giving you the elapsed time. When time is up, you remove the cake from the oven.
Think about it for a minute. What if you wanted to time two events? Setting millis back to zero would hardly work then, would it? Setting it to zero for the second event would corrupt your timing for the first event.
However noting the time each one starts, and comparing the time now to the start time, will work for any number of events.
For more details see my post about millis() overflow ... a bad thing?
Nick Gammon
  • 38,901
