About 3 years ago Sparkfun had a sale on Arduino Minis, so I bought 6 of them (3 x 3.3 V @ 16 MHz and 3 x 5 V @16 MHz). I used two of them for separate projects (everything worked flawlessly) then stored the rest. Then last night I grabbed one of the 5 V and 3.3 V Minis and tried to upload the Blinking LED program to them. But I kept getting this error:
I'm getting similar results on all of these computers: Mac OS X 10.10, Mac OS X 10.7, and Windows 7. I tested with default drivers and I tried installing fresh drivers based on the HardwareID's of the devices. I used both the newest version of Arduino IDE and a few older versions.
I've tried two different USB devices: Sparkfun Basic FTDI and a Generic USB to Serial PL2303 similar to this one. They both produce the same error, however the FTDI seems to be somewhat able to communicate since the RX & TX lights are flashing as well as the Arduino LED. With PL2303, the LED is lit constantly.
While searching last night, I found a few forums where people suggested things like hitting the reset button and selecting different Arduino boards in the IDE.
Greenonline
  • 3,152
  • 36
  • 48
Tim
  • 53
Things have changed in the three years since you last used your FTDI board.
Most importantly avrdude has changed.
You will most likely find that you can program your boards perfectly fine using Arduino IDE 1.0.1.
What has changed is that avrdude has been modified to counter a change in the FTDI drivers. It used to be that the FTDI drivers would pulse the DTR line when the port was opened, but that stopped happening with newer drivers. So AVRDude started asserting the DTR line instead. However it doesn't pulse it, it just holds it low.
The problem with that is if the DTR is connected direct to the RESET pin the main chip is held in reset mode all the time instead of it just being reset briefly to reset the board.
The "fix" is to place a 100nF capacitor between DTR and RESET instead of directly connecting it. That converts the steady low into a short pulse which resets the board and enters the bootloader.
Majenko
  • 105,851
  • 82
  • 139
For programming a Pro Mini, I find the CP2104 adaptor works better than the FTDI or PL2303 based units, on both Mac and PC. You can find the CP2104 adaptor from many sources, such as TxHang Electronic:
http://www.ebay.com/itm/USB-2-0-TTL-UART-6PIN-Module-Serial-Converter-CP2104-STC-PRGMR-Replace-CP2102-/200958955841?hash=item2eca165141
(You may need to install CP2104 software drivers on some platforms) This is how I wire them together:
  • CP2104_________PRO MINI
    • DTR------------DTR
    • 3.3V--------- - * NOT USED (VCC)
    • 5V --------- - -* NOT USED (VCC)
    • TXD------------RXD
    • RXD------------TXD
    • GND-----------GND
    Note: * While you may be able to power your (unloaded) Pro Mini from your CP2104 adaptor, it's better to use a separate supply that is appropriate for the version of the Pro Mini you use. Good luck. /DerrickA
