Arduino IDE is throwing this error when uploading sketches - avrdude: stk500_recv(): programmer is not responding
The problem arose just after I uploaded a blink sketch to my Arduino Mini, which worked absolutely fine. After the successful upload I tried to upload a different sketch and got the error.
I thought I had destroyed the boot loader somehow and was about to get out the Bus Pirate for ICSP but I decided to try another Arduino Mini I had lying around (albeit from another manufacturer) and got the same error.
So I'm convinced it's a driver issue as I successfully uploaded a sketch (it still runs as we speak!) then just magically without changing ANYTHING I can no longer upload.
In a futile attempt to get back to work I've done the following: Switched the RX-TX lines (clearly not the issue as the first upload worked) Used a different FTDI cable used a different programmer (FTDI 5V/3.3V USB to TTL Basic FT232 FIO Programmer) (USB to TTL Serial UART RS232 Adaptor (PL2303HX) I'm fairly certain these use different drivers - FTDI and Prolific
Please help me I'm about to murder something :'(
Screencaps of error and device manager - Imgur
totalconfusion
  • 151
Is it this?
"To upload a new sketch to the Arduino Mini, you need to press the reset button on the board immediately before pressing the upload button in the Arduino environment."
https://www.arduino.cc/en/Guide/ArduinoMini
Aaron Cooper
  • 171
Is it this?
"To upload a new sketch to the Arduino Mini, you need to press the reset button >on the board immediately before pressing the upload button in the Arduino >environment."
You sir, are a hero.
I don't even know how I accidentally did this sequence to upload the first sketch... Perhaps I plugged the USB to Serial UART in to the USB port and quickly pressed upload? Having got the first sketch on there really mixed me up :/
Solution:
  1. Click upload sketch - It will show 'Compiling Sketch'
  2. Immediately after clicking upload, hold the reset button down on the Arduino mini
  3. Release the reset button when 'Compiling Sketch' turns in to 'Uploading'
totalconfusion
  • 151
I have the same problem (Arduino uno) I reset the Arduino several times, but finally i fixed the problem. so you must change the pic of the arduino and make sure it was instilled correctly on the arduino board.
hope it work...
