I've written a Arduino sketch that converts an analogue voltage to a temperature using a lookup table - code below. I've recently changed my LUT to include more values but ever since that my Serial monitor won't print out my debugging statements etc. So I limited the number of elements in the array and it was back to normal. But when I enter more debugging statements using the serial monitor, there is garbage before my statements (still readable though when I parse through it myself) or at the start nothing is printed. I've checked that the two baud rates are the same but I just find it peculiar that if I take some of my println() statements out it runs okay. Tested everything else with a "Hello World" example but in the simple exaples the monitor works fine.
#####PROJECT DESCRIPTION#####
Measures temperature with an Arduino and NTC Thermistor (10Kohms @ 25^C) in a voltage divider circuit
Since the response is non-linear, a lookup table is used since there is a non linear response
The values in the LUT are the predicted values of the ADC at temperature between 6^C and 40^C
LUT has been derived from the calibration tests
//#####CONSTANTS#####
const int constDelay = 3000; //constant delay for program
const int constNoOfAnaloguePins = 2; //number of analogue pins that are to be read
const int errReturn = 998; //error value that is returned ***CHECK FOR CONSITENT VALUE ACROSS FUNCTIONS***
//#####VARIABLE DECLARATIONS#####
float avgTempC; //float var to store average of multiple temp readings
//#####SETUP PROCEDURE#####
void setup()
//this is the Setup part of your project - this is for code that is run only ONCE at startup
for (int analoguePinCounter = 0; analoguePinCounter < constNoOfAnaloguePins; analoguePinCounter++) //for loop to set up numerous analogue pins
pinMode(analoguePinCounter, INPUT); //set pin mode of the analogue thermistor input
}//end for
analogReference(INTERNAL); //use the interval votlage of 1.1V for the ADC resolution
Serial.begin(9600); //serial monitor baud rate
}//end Setup function
//#####LOOP PROCEDURE#####
void loop()
//this is the main part of your project - put all continuously running code here
for (int analoguePinCounter = 0; analoguePinCounter < constNoOfAnaloguePins; analoguePinCounter++) //for loop to take temp readings from each analogue pin
//get LPF average reading over 25 samples
avgTempC = LPF(analoguePinCounter, 25);
//print out the readings
if (avgTempC < float(errReturn)) //there hasn't been any temps outside the range ***CHECK THE VALUE RETURNED FROM LPF IF ERROR***
Serial.print(analoguePinCounter);
Serial.print(" | Average Temperature Readings = ");
Serial.print(avgTempC, 2);
Serial.println(" degC.");
Serial.println("-------------------------");
else //avgTempC has returned X indicating an error
Serial.println("**ERROR IN READING AVERAGE TEMP**");
delay(10);
}//end if
delay(constDelay/2); //wait X/2 seconds until moving onto next sensor
}//end for
delay(constDelay); //wait X seconds until next loop
}//end Loop function
#####LOW PASS FILTER DESCRIPTION#####
This function is a LPF for smoothing out signals or averaging
It uses a static buffer to store the last "n" readings, and each time it is called,
the oldest reading is discarded, the new reading is added, and the stack average
value is returned.
The buffer size is user-adjustable, but is constrained between 2 and 50
An initialization function fills the entire buffer with the input value.
This is useful when the LPF function is called for the first time.
Note: To meet the definition of a true LPF, this function must be called at regular intervals.
//#####LOW PASS FILTER FUNCTION#####
float LPF(int pinAnalogue, int bufferSize)
//##PRE PROCESSOR##
#define bufferCap 75 //maximum buffer capacity
//##CONSTANTS##
const int constMAXERRORS = 5; //max number of error that can occur
const int errReturn = 998; //value return if there is an error
//##VARIABLES##
float tempC; //var to store instantaneous temp
static float buffer[bufferCap]; //array to act like a 'stack' of temp values ***DOES IT NEED TO BE STATIC NOW?***
float tempSum; //to store the sum of the temperatures
float output; //return value of LPF which is the average of the temp readings
int errCounter = 0; //initialise error counter to 0
//make sure buffer size is between the range
bufferSize = constrain(bufferSize, 2, bufferCap);
for (int i=0; i<bufferSize; i++) //for loop to store temps in buffer array
tempC = getTempFloat(pinAnalogue); //call function to get temperature from pin
if ((tempC > -errReturn) && (tempC < errReturn)) //no error
buffer[i] = tempC; //store temp value into array
else //error
errCounter++; //increment counter for number of erroneous readings
i--; //decrement counter as to not skip a sample index
if (errCounter > constMAXERRORS)
return(errReturn+1.0); //return the error value + 1
}//end if
}//end if
delay(25); //allow the ADC to settle
}//end for
//calculate current stack average
tempSum = 0; //initialise sum total
for (int i=0; i<bufferSize; i++) //go through stack array
tempSum = tempSum + buffer[i]; //total up readings
}//end for
//average sum
output = tempSum/bufferSize;
return(output);
}//end LPF function
#####GET TEMP FLOAT DESCRIPTION#####
This function converts a thermistor reading into a corresponding temp in ^C
The thermistor is incorporated into a Voltage Divider Circuit:
+Vref---[Thermistor]---+--[1.8K]---GND
ADC @ thermPin
ADC Values were externally calculated from the calibration table using: ADC = 1023*10000/(Rtherm+10000)
The LUT is an array of integer constants containing the predicted ADC values for all temperatures between +6^C to +40.5^C.
The array index starts at zero, which corresponds to a temperature of +6^C.
A linear interpolation between the two closest entries is performed to give a finer output resolution.
float getTempFloat (int thermPin)
//##CONSTANTS##
/*1K8*/
const int constLUTArraySize = 431;
const int LUT_Therm[constLUTArraySize] = //LUT containing ADC values
223, 224, 225, 226, 227, 228, 229, 230, 231, 232, //7^C to 7.9^C
233, 234, 235, 236, 237, 238, 239, 240, 241, 242,
244, 245, 246, 247, 248, 249, 250, 251, 252, 253,
255, 256, 257, 258, 259, 260, 261, 263, 264, 265,
266, 267, 268, 269, 271, 272, 273, 274, 275, 277,
278, 279, 280, 281, 283, 284, 285, 286, 287, 289,
290, 291, 292, 294, 295, 296, 297, 299, 300, 301, //13^C to 13.9^C
302, 304, 305, 306, 308, 309, 310, 312, 313, 314,
315, 317, 318, 319, 321, 322, 323, 325, 326, 327,
329, 330, 332, 333, 334, 336, 337, 338, 340, 341,
343, 344, 345, 347, 348, 350, 351, 353, 354, 355,
357, 358, 360, 361, 363, 364, 366, 367, 369, 370,
371, 373, 374, 376, 377, 379, 380, 382, 383, 385,
387, 388, 390, 391, 393, 394, 396, 397, 399, 400,
402, 404, 405, 407, 408, 410, 411, 413, 415, 416,
418, 419, 421, 423, 424, 426, 428, 429, 431, 433,
434, 436, 438, 439, 441, 443, 444, 446, 448, 449,
451, 453, 454, 456, 458, 460, 461, 463, 465, 466,
468, 470, 472, 473, 475, 477, 479, 480, 482, 484,
486, 488, 489, 491, 493, 495, 497, 498, 500, 502,
504, 506, 507, 509, 511, 513, 515, 517, 519, 520,
522, 524, 526, 528, 530, 532, 534, 535, 537, 539,
541, 543, 545, 547, 549, 551, 553, 555, 557, 559,
560, 562, 564, 566, 568, 570, 572, 574, 576, 578,
580, 582, 584, 586, 588, 590, 592, 594, 596, 598,
600, 602, 604, 606, 608, 611, 613, 615, 617, 619,
621, 623, 625, 627, 629, 631, 633, 635, 638, 640,
642, 644, 646, 648, 650, 652, 655, 657, 659, 661,
663, 665, 667, 670, 672, 674, 676, 678, 680, 683,
685, 687, 689, 691, 694, 696, 698, 700, 702, 705,
707, 709, 711, 714, 716, 718, 720, 723, 725, 727,
729, 732, 734, 736, 738, 741, 743, 745, 747, 750,
752, 754, 757, 759, 761, 764, 766, 768, 771, 773,
775, 778, 780, 782, 785, 787, 789, 792, 794, 796,
799, 801, 803, 806, 808, 811, 813, 815, 818, 820,
822, 825, 827, 830, 832, 834, 837, 839, 842, 844,
847, 849, 851, 854, 856, 859, 861, 864, 866, 868,
871, 873, 876, 878, 881, 883, 886, 888, 891, 893,
896, 898, 901, 903, 906, 908, 911, 913, 916, 918,
921, 923, 926, 928, 931, 933, 936, 938, 941, 943,
946, 948, 951, 953, 956, 958, 961, 963, 966, 969,
971, 974, 976, 979, 981, 984, 987, 989, 992, 994,
997, 999, 1002, 1005, 1007, 1010, 1012, 1015, 1017, 1020, //40^C to 49.9^C
1023 //50^C
//##VARIABLES##
float _tempC; //intermediate results + final temperature return value
int ADC_Lo; //the lower ADC matching value
int ADC_Hi; //the higher ADC matching value
float Temp_Lo; //the lower number matching temperature
int mapTemp_Lo; //the lower number that will be entered into the map function
float Temp_Hi; //the higher number matching temperature
int mapTemp_Hi; //the higher number that will be entered into the map function
//prep ADC onto that particular analogue pin to sort out multiplexing etc
analogRead(thermPin);
delay(10);
//get raw ADC value from VDR
int thermValue = analogRead(thermPin);
//Serial.println(thermValue);
/*Serial.print("PinNo : ");
Serial.println(thermPin);*/
Serial.print("ADC : ");
//return dummy value if the sensor reading falls outside of the LUT
if (thermValue < LUT_Therm[0]) //less than the least ADC value
_tempC = -errReturn-1; //under range dummy value
else if (thermValue > LUT_Therm[constLUTArraySize-1]) //more than the greatest ADC value
_tempC = errReturn+1; //over range dummy value
else //value falls in LUT range
for (int i=0; i<constLUTArraySize; i++) //step through LUT and look for a match
if (LUT_Therm[i] > thermValue) //LUT value is greater than the reading
//find the closest higher ADC value
ADC_Hi = LUT_Therm[i];
//record the closest higher temperature
Temp_Hi = float(i/10) + 13.0; //convert to temp
//get the closest lower temperature - taking the lower table boundary into account
if (i != 0) //general case -> as long as it is not the first entry
ADC_Lo = LUT_Therm[i-1]; //store the previous array element as the low
Temp_Lo = float(i/10) + 13.0 - 0.1; //convert to temp
else //special case -> counter = 0 ie first array entry
ADC_Lo = LUT_Therm[i]; //store the first array element
Temp_Lo = i - float(i/10) + 13.0; //convert to temp
}//end if
//interpolate the temperature value for greater precision
//NB the map function does not use floating-point math, so the int values of temp are multiplied by 100 and then result is subsequently divided by 100
mapTemp_Lo = Temp_Lo*100;
mapTemp_Hi = Temp_Hi*100;
_tempC = float(map(thermValue,ADC_Lo,ADC_Hi,mapTemp_Lo,mapTemp_Hi))/100;
break; //exit for loop after the match is detected
}//end if
}//end for
}//end if
return(_tempC);
}//end getTempFloat function
In this particular sketch no output is seen on the serial monitor. Has anyone come across this before or have any ideas how I could fix this?
