I am using an Arduino UNO along with a Cooking Hacks CAN Bus Module and Multiprotocol Radio Shield. The CAN module is connected to the radio shield which is plugged into the Arduino. I got this radio shield keeping future applications in mind where I can combine multiple protocols, for eg. CAN and Bluetooth.
I connected them through an OBD2-DB9 cable to the car's OBD port but noticed that I was not really getting any messages. Well I am getting messages but just:
   -- Constructor Can(uint16_t speed) --
   SPI configured
   The MCP2515 has been successfully reset, configuration mode activated
   Speed=500kps
   -- End Constructor Can(uint16_t speed) --
   Data in buffer 0
   id: 7FF  rtr: FFFFFFFF => Data in buffer 0
After analysing the connections, I realised that the hardware is probably fine since the continuity between the pins of the cables is fine and the CAN module(MCP2515 + MCP2551) is receiving power and I also checked the voltages at the pins and think they're mostly fine apart from a few pins which I'm not sure about. Which brings me to the software issue. I can see that the SPI is not getting configured properly and the MCP2515 controller doesn't enter configuration mode which means the bit times defined are not being used and hence the controller is not initialising like it should. I even tried manually changing to configuration mode by changing the values of the REQOP bits of the CANCTRL register as opposed to doing a software reset which was how I was doing it initially. Even then, no luck. To verify the SPI connection, I chose a random read/write control register like BFPCTRL and wrote a value to it and then read it back to verify that it matched the values I wrote. However, the value read back is not the same as the value I wrote. Also, the controller only has trouble going into configuration mode. It seems to change to normal and listen only mode without problem since the CANSTAT register displays the correct values for the REQOP bits. I don't understand why the controller has problem entering configuration mode but no problem changing to the other modes. Can anybody help me?
SPI Code:
    bool CAN::begin(uint16_t speed)
    #if (DEBUGMODE ==1 )
    Serial.println("-- Constructor Can(uint16_t speed) --");
    #endif
    //Initialization SPI
    SPI.begin();
    SPI.detachInterrupt();
    SPI.setBitOrder(MSBFIRST);
    // both mode 0 & 3 should work
    SPI.setDataMode(SPI_MODE0);
    //Set the SPI frequency
    SPI.setClockDivider(SPI_CLOCK_DIV4);
    #if (DEBUGMODE==1)
    Serial.println("SPI configured");
    #endif
    //Configure MCP2515 pins
    pinMode(CAN_CS,OUTPUT);
    pinMode(CAN_INT,INPUT);
    digitalWrite(CAN_CS,HIGH);
    writeRegister(BFPCTRL, (1<<B0BFM) | (1<<B1BFM));
    int dat = readRegister(BFPCTRL<<2);
    Serial.println(dat);
    //Software resets MCP2515
    reset();
    delay(100);
    //After the reset, controller enters configuration mode
    dispMode();
When I read back the values of B0BFM and B1BFM bits, they should be 1 but the display says that their values are 0.
   void CAN::writeRegister( char direction, char data )
   //CS low to select the MCP2515
   digitalWrite(CAN_CS,LOW);
  SPI.transfer(SPI_WRITE);
  SPI.transfer(direction);
  SPI.transfer(data);
  //CS line again to release
  char CAN::readRegister(char direction)
  char data;
  SPI.transfer(SPI_READ);
  //Read data SPI
  data = SPI.transfer(0xff);
  return data;
In SPI protocol you'll need to read the SPI buffer twice because the data you wrote will be read by the IC and the IC will respond to it in the next communication and that's when you know.
Also, by looking at the message, I see that your IC is working fine, but is your CAN bus initialised properly? I'm a FSAE team member and I've faced this issue with the CAN Bus termination resistances and the ODB-II configuration on the Sparkfun CAN Bus shield.
Also, have you tried any other libraries for the CAN Shield? For me the seeedstudio library of their CAN shield worked very well.
Greenonline
  • 3,152
  • 36
  • 48
