Make newArray be a pointer to whichever array you wish to work with. For example:
int myArray1[] = {0, 2, 4, 5, 7, 9, 11};
int myArray2[] = {0, 2, 3, 5, 7, 8, 10};
int myArray3[] = {0, 3, 5, 6, 7, 10};
int *newArray = myArray2;
// ... work with selected array, via newArray[] subscripting
Note, you may need to set an array-length variable at the same time as choosing the array.
For example:
int newSize = sizeof(myArray2)/sizeof myArray2[0];
newArray = myArray3;
newSize = sizeof(myArray3)/sizeof myArray3[0];
Alternately, add an array-end marker at the end of each array (eg, a negative number), or more elegantly, make all the arrays the same length.
If you want to make a new copy of the original array, such that modifying the new array won't change the old, use (eg) memcpy(). For example:
int newArray[7];
memcpy(newArray, myArray2, sizeof(myArray2));
Note that memcpy()'s size argument is given in bytes. Also, if you need to declare memcpy() [I don't recall whether it's automatically declared in the Arduino environment], add #include <string.h> up front.
