I know it's pretty standard to set up an Arduino system as a BLE client, and use something like an app running on a smartphone as the GATT server, which receives the data and does something with it.
In my scenario I have a BLE sensor that is not connected directly to the Arduino system, and I want the Arduino to be able to respond to the sensor output (a wearable accelerometer) and, for example, initiate various lighting sequences depending on the data being received.
I would prefer not to introduce a third component (ie: mobile device as GATT server) into the equation. I'd like for the Arduino to listen to the remote device's services and characteristics, analyze the incoming data and then make some decisions about what LEDs to illuminate based on that analysis.
Can an Arduino run as a GATT server?
dda
  • 1,595
Tom Auger
  • 193
An ESP32 module (Arduino IDE compatible) can act as both a GATT Client and Server, and there are module examples for each of these, as well as github projects.
I got this link here that could be helpful - link at the bottom. It is a tutorial that shows you how to control your Arduino with a custom app on an Android. It uses the MIT app creator, an app that lets you create an app. You program it with there IDE in some Java I believe. You can add button to your app so that is sends a message to your Arduino then program the Arduino to do something when it receives that message. For the Arduino side, you could buy an HC-05 Bluetooth module. It is both an transmitter and receiver. It is quite cheap and very popular so there is many libraries out there. I think this is a good module you should get and I recommend to get them in pairs so you can connect them together with 2 Arduinos.
https://www.youtube.com/watch?v=E-1w7dL3Cps
Dat Ha
  • 2,943
  • 46
