I have a bricked Arduino Uno and I want to try to flash the bootloader. I'm trying to figure out how to do it. On this tutorial from SparkFun you can see this diagram:
They also show this table of the pinout
That seems simple enough but it's totally different than the official tutorial, "Circuit (targeting Arduino Uno, Duemilanove, or Diecimila)"
Which also says
An Arduino board serving as an ISP to program the ATmega on another Arduino board. On the Arduino Uno, you'll need to connect a 10 uF capacitor between reset and ground (after uploading the ArduinoISP sketch). Note that you need access to the reset pin on the target board, which isn't available on NG or older boards.
So do I need a 10 uF capacitor between reset and ground? How do I put a 10 uF capacitor in between reset and ground when, in this configuration, reset is connected to PIN 10? Why are there two configurations? What's the upsides and downsides to either of them?
