I have a program where a device registers itself with a command object. The command object is losing track of the registrations. The following program repeats "0 devices registered" even though when it initializes it displays "Devices registered 1". My guess is that I am accidentally creating 2 copies of the command object. This is the main sketch
#include "command.h"
#include "widget.h"
Command command;
Widget widget;
  command.init();
  widget.init(command);
  command.update();
command.h
#include "Arduino.h"
#ifndef Command_h
#define Command_h
typedef struct  {
  char id;
  char name[20];
} Device;
class Command
  public:
    Command();
    void init();
    void registerDevice(Device _cmd);
    void update();
  private:
    Device Devices[20];
    byte DevicesPtr = 0;
#endif
command.cpp
#include <Arduino.h>
#define DEVICES_MAX 9
Command::Command() {
  DevicesPtr = 0;
  Device Devices[DEVICES_MAX];
void Command::init() {
  Serial.begin(9600);
void Command::update(){
  Serial.print( DevicesPtr );
  Serial.println( " devices registered" );
  delay(500);
void Command::registerDevice(Device _cmd) {
  _cmd.id = '0' + (++DevicesPtr);
  Devices[DevicesPtr] = _cmd;
  Serial.print("Devices registered ");
  Serial.println(DevicesPtr);
widget.h
class Widget
  public:
    static void init(Command _command);
  private:
widget.cpp
#include "widget.h"
void Widget::init(Command _command) {
  Device device;
  strcpy(device.name, "Widget #1");
  _command.registerDevice(device);
CarbonMan
  • 233
It is all about calling conventions and argument binding. The code is using call-by-value when it should be call-by-reference.
This is call-by-value (the incoming command is not updated, a copy is passed as parameter):
This is call-by-reference (a pointer to command is passed as parameter):
void Widget::init(Command* _command)
   __command->registerDevice(...);
widget.init(&command);
Alternative syntax is:
void Widget::init(Command& _command)
   _command.registerDevice(...);
Cheers!
Mikael Patel
  • 7,989
