At the moment I am working on a code that should send a plateau to a certain position and back. The plateau is being moved by the stepper, in my case a Nema 17 with a Polulu DRV8825 driver. Everything is hooked up correctly. My goal is to press '4' on the keyboard and that then the stepper moves to a certain position. However, I am not succeeding in this. I am using AccelStepper and at the moment I have the following code:
#include <AccelStepper.h>
AccelStepper stepper(1, 5, 4);
int spd = 1000;    // The current speed in steps/second
int sign = 1;      // Either 1, 0 or -1
int buttonState = 0;
void setup()
  Serial.begin(9600);
  stepper.setMaxSpeed(1000);
  stepper.setSpeed(1000);
void loop()
  char c;
  if (Serial.available()) {
    c = Serial.read();
    if (c == 'f') {  // forward
      sign = 1;
    if (c == 'r') {  // reverse
      sign = -1;
    if (c == 's') {  // stop
      sign = 0;
    if (c == '1') {  // super slow
      spd = 100;
    if (c == '2') {  // medium
      spd = 900;
    if (c == '3') {  // fast
      spd = 1000;
    if (c == '4') {
      //not working, does anyone know how to do this?
      stepper.moveTo(500);
    stepper.setSpeed(sign * spd);
  stepper.runSpeed();
Does anyone have tips or know how to achieve this?
Thanks is advance!
zx485
  • 256
user15514
Gerben's comment:
You need to call stepper.run() instead of runSpeed, for moveTo to work.
provides the answer. The updated code is:
void setup()
  Serial.begin(9600);
void loop()
  char c;
    c = Serial.read();
      sign = 1;
      sign = -1;
      sign = 0;
      spd = 100;
      spd = 900;
      spd = 1000;
    if (c == '4') {
  stepper.run(); //You need to call stepper.run() instead of runSpeed, for moveTo to work. – Gerben
Dave X
  • 2,350
  • 29
