I am using sevseg and i can't get more than 8 digits to work. I really need 15. Does somebody know what I can do to get this?
Shown is the original example
This is using Gabriel Staples example in the sevseg library:
#include <SevSeg.h>
SevSeg sevseg; //Instantiate a seven segment controller object
void setup()
  byte numDigits = 4; //<<---I am wanting 15, but doesn't work after 8------
  byte digitPins[] = {2, 3, 4, 5}; //Digits: 1,2,3,4 <--put one resistor (ex: 220 Ohms, or 330 Ohms, etc, on each digit pin)
  byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13}; //Segments: A,B,C,D,E,F,G,Period
  sevseg.begin(COMMON_ANODE, numDigits, digitPins, segmentPins);
// Note: 100 brightness simply corresponds to a delay of 2000us after lighting each segment. A brightness of 0
// is a delay of 1us; it doesn't really affect brightness as much as it affects update rate (frequency).
// Therefore, for a 4-digit 7-segment + pd, COMMON_ANODE display, the max update rate for a "brightness" of 100 is 1/(2000us*8) = 62.5Hz.
// I am choosing a "brightness" of 10 because it increases the max update rate to approx. 1/(200us*8) = 625Hz.
// This is preferable, as it decreases aliasing when recording the display with a video camera....I think.
  sevseg.setBrightness(10);
void loop()
  //local vars
  static byte decPlace = 0;
  sevseg.setNumber(8888,decPlace);
  decPlace++;
  decPlace %= 4; //rollover back to 0 once variable gets to 4; To anyone wondering: the % is called the "modulo" operator; see here for explanation & example: https://www.arduino.cc/en/Reference/Modulo
  sevseg.refreshDisplay(); // Must run repeatedly; don't use blocking code (ex: delay()) in the loop() function or this won't work right
Using the following code, I can't get the 3rd set of 5 numbers to display. I have changed the sevseg.h file to 15, but that shouldn't matter:
#include <SevSeg.h>
SevSeg sevseg1;//Instantiate a seven segment controller object 1
SevSeg sevseg2;//Instantiate a seven segment controller object 2
SevSeg sevseg3;//Instantiate a seven segment controller object 3
void setup()
  Serial.begin(9600);
byte segmentPins[] = {22, 23, 24, 25, 26, 27, 28, 34}; //Segments:     A,B,C,D,E,F,G,Period
  byte digitPins1[] = {29, 30, 31, 32, 33};
  sevseg1.begin(COMMON_CATHODE, sizeof(digitPins1), digitPins1,  segmentPins);
  sevseg1.setBrightness(10);
  byte digitPins2[] = {35, 36, 37, 38, 39};
  sevseg2.begin(COMMON_CATHODE, sizeof(digitPins2), digitPins2, segmentPins);
  sevseg2.setBrightness(10);
  byte digitPins3[] = {40, 41, 42, 43, 44};
  sevseg3.begin(COMMON_CATHODE, sizeof(digitPins2), digitPins3, segmentPins);
  sevseg3.setBrightness(10);
void loop()
static byte decPlace = 2;
  sevseg1.setNumber( 12345, decPlace );
  sevseg2.setNumber( 12345, decPlace );
  sevseg3.setNumber( 12345, decPlace );
  sevseg1.refreshDisplay();
  sevseg2.refreshDisplay();
klarson18
  • 29
You can change the pre-defined maximum number of digits at the top of the SevSeg.h header file to as many as 10, if you use long or unsigned long when you call setNumber. It is defined here, on line 27:
#define MAXNUMDIGITS 8 //Increase this number to support larger displays
This the version referenced from the Arduino Playground SevSeg. Be sure to use the same number in your modulo, too:
void loop()
  //local vars
sevseg.setNumber(8888,decPlace); decPlace++; decPlace %= 10; //rollover back to 0 once variable gets to 10
decPlaces is mostly useful for floating-point numbers: it specifies how many digits after the decimal point should be displayed. For integer values, it specifies how many leading zeroes will be displayed.
However (as you discovered), you cannot call setNumber with anything larger than a long, so you are limited to 10 or fewer digits for MAXNUMDIGITS. (There is no byte overflow -- it's just limited to the number of decimal digits in 232-1.) This is a limit of one SevSeg instance. You could have two instances of SevSeg like this:
#include <SevSeg.h>
SevSeg sevseg1;
SevSeg sevseg2;
void setup() { byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13}; //Segments: A,B,C,D,E,F,G,Period
byte digitPins1[] = {2, 3, 4, 5, 22, 23, 24}; sevseg1.begin(COMMON_ANODE, sizeof(digitPins1), digitPins1, segmentPins); sevseg1.setBrightness(10);
byte digitPins2[] = {14,15,16,17,18,19,20,21}; sevseg2.begin(COMMON_ANODE, sizeof(digitPins2), digitPins2, segmentPins); sevseg2.setBrightness(10);
sevseg1.setNumber( 7654321UL, 7 ); sevseg2.setNumber( 87654321UL, 8 ); }
void loop() { sevseg1.refreshDisplay(); sevseg2.refreshDisplay(); }
The first instance handles 7 digits, and the second instances handles 8 digits. Note the use of "UL" to force and unsigned long call.
Update 11-DEC-2015
First, the MAXNUMDIGITS is the maximum per instance, so you could set it to 5 to save some precious RAM.
Second, you have a copy and paste error:
sevseg2.refreshDisplay();   <--  Oopsies!  :)
Third, I assume the setNumber calls are placeholders for what you're really going to use. Since they always set the same value, they could be in setup. In your final program, there must be some input that will be used to calculate a number to display with setNumber.
slash-dev
  • 2,029
Looking at the sevseg README file on GitHub I find this:
If you wish to use more than 8 digits, increase MAXNUMDIGITS in SevSeg.h.
Have you done that? Seems like that might be the problem.
As @slash-dev said, be sure to also modify the loop() code as well:
void loop()
  //local vars
  decPlace++;
  decPlace %= numDigits;
I think it makes more sense to use numDigits rather than a hard coded constant that you have to remember to change whenever you change the number of digits in your display. It would be worth checking the code for any other hard coded constants. If space is an issue, it might be worth checking to see if using a #define results in smaller code than using a variable – in any case do something to avoid needing to understand what "magic numbers" are doing. This is especially important when the same numeric value (e.g., 4) is being used for multiple reasons. Then it gets hard if you need to change the value as you have to understand the purpose behind each use.
dlu
  • 1,661
  • 29
