What I have:
- 1 x 8 channel relay
- 1 x IR receiver
- 1x Arduino Uno
- 1x momentary switch
- 1x breadboard
- 1x 10K resister
I think the wiring is all ok as for the most part things are working as they should..ish.
Just a few bugs I need to fix.
The goal was to toggle just 2 relays (at the moment) on/off with the hardwired switch and individually toggle the a relay using an IR remote control.
Like I said this sort of works....
If I press the momentary button it does indeed toggle both relays...yeah! then as long as the 2 relays are toggled to the on position by the momentary switch I can toggle each relay using buttons on a remote.
However if I turn the relays off with the momentary button I can't turn them on with the remote. Also if I turn off one of the relays with the remote and then press momentary switch it alternates the toggle between the 2 relays rather than just turning the other one off.
I have been using various example sketches to achieve all this and just trying to stitch them together as best I can but something is telling me that the approach is all wrong and that I should maybe be looking into Boolean's perhaps?
Hope you can shed some light on this for me.
#include <IRremote.h>
#define irPin 8
IRrecv irrecv(irPin);
decode_results results;
const int buttonPin = 2;
const int relay1 = 13;
const int relay2 = 12;
int relay1State;
int relay2State;
int buttonState;
int lastButtonState;
long lastDebounceTime = 0;
long debounceDelay = 50;
Serial.begin(9600);
irrecv.enableIRIn();
pinMode(buttonPin, INPUT);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
digitalWrite(relay1, relay1State);
digitalWrite(relay2, relay2State);
if (irrecv.decode(&results)) {
switch (results.value) {
case 0xFF30CF:
Serial.println("Button 1 Pressed");
relay1State = ~relay1State;
delay(250);
break;
case 0xFF18E7:
Serial.println("button 2 pressed");
relay2State = ~relay2State;
delay(250);
break;
irrecv.resume();
int reading = digitalRead(buttonPin);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == HIGH) {
relay1State = !relay1State;
relay2State = !relay2State;
lastButtonState = reading;
