Can someone tell me how fast the built in DAC (and ADC) in an Arduino Due can be written or read? I currently don't have the equipment to measure but need the information to plan my next steps.
I try to move galvanometer mirrors and want to make the voltage/position updates as small as possible. How fast are the internal DACs compared to an SPI connection (where I have to write 2 Byte).
FooTheBar
  • 192
See sections 43, Analog-to-Digital Converter (ADC), and 44, Digital-to-Analog Converter Controller (DACC), in the Atmel-11057-32-bit-Cortex-M3-Microcontroller-SAM3X-SAM3A_Datasheet.pdf specsheet.
In particular, subsection 43.2, Embedded Characteristics, says: “1 MHz Conversion Rate”. Some time diagrams appear quite a few pages later that suggest 10-bit conversions can be done more rapidly than 12-bit.
For the DAC (or DACC, per the specsheet), section 44.6, Functional Description, says:
The DACC uses the master clock (MCK) divided by two to perform conversions. This clock is named DACC Clock. Once a conversion starts the DACC takes 25 clock periods to provide the analog result on the selected analog output.
AIUI, the Due's master clock frequency is 84 MHz, so DACC Clock frequency is 42 MHz, whence 25 cycles take 575 ns, which is an update frequency of about 1.74 MHz.
For more details about the ADC, see eg Analog performance, particularly of Due's 12 bit ADC at djerickson.com.
James Waldby - jwpat7
  • 8,920
  • 33
