I'm trying to better understand what is going on behind the Arduino IDE. First off I am no expert in C or writing firmware to boards but do have experience in real development.
I see currently the Arduino IDE is one big vast library we first select our board. What I don't understand is where are our header files? The source files for the board you select?
Not only that we use a number of functions already detected within the IDE where are these located also is any of this code editable?
I had a look through the Arduino directory and most of this stuff looks like its Java I was hoping for C files. Thanks for any links, help or info anyone can give.
702cs
  • 179
Just check the source code. Specifically look at Arduino.h, main.cpp and wiring*.
These files should also be present in the Arduino application folder somewhere, but you'll have to go through quite a few subfolders to find them.
The different boards have different .h file that will specify the pin-numbers and other chip specific data.
The "auto detect" functionality is done by keywords.txt files. At least for libraries. That way if you install a new library with keywords.txt file, the library functions-names are recognized.
The processes of taking all these files, and the users code, and compile it all whole story on it's own.
Gerben
  • 11,332
  • 22
  • 34
