This is more of a C/C++ question. However the files I am asking about are a part of the Arduino library.
In /arduino-1.6.5-r5/hardware/arduino/avr/cores/arduino/Arduino.h :
#ifndef Arduino_h
#define Arduino_h
#include <stdlib.h>
#include <stdbool.h>
#include <string.h>
#include <math.h>
#include <avr/pgmspace.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include "binary.h"
#ifdef __cplusplus
extern "C"{
#endif
How are these blocks found at compile time in the main sketch?
#include <avr/io.h>
Does #include <avr/somelibrary.h> mean that this is a standard library from either avr-g++ or avr-gcc? As opposed to a standard g++ or gcc compiler?
One last question, how can there be an Arduino.h without an Arduino.c? I searched through the project but could not find an Arduino.c. All of these are probably stupid questions, as I am in the process of learning C/C++. I am completely new to it.
VE7JRO
  • 2,515
  • 29
wgwz
  • 149
No. It simply means that the compiler should check both its built-in include paths as well as any passed via the -I command line option (or its local equivalent) for a file called "avr/somelibrary.h". That AVR GCC knows where AVR Libc is located is incidental.
There is no obligation to match each header file with a .c/.cc/.cpp file, or vice versa.
Ignacio Vazquez-Abrams
  • 17,733
  • 28
I think after all this time, you may found the answers for your question.
But to add some information to this topic incase if anyone opened this question.
Does #include mean that this is a standard library from either avr-g++ or avr-gcc? As opposed to a standard g++ or gcc compiler?
Yes, what is included with avr/ is related to avr standard libraries, which is also found in avr standard compilers.
Because, as Mr @Ignacio Vazquez-Abrams answered that there's no obligation for connecting the header file for anything else. You can write multiple header files and use them for one source file.
R1S8K
  • 283
