Hi i'm new to AVR assembly language so i was trying to get delay function to create 1 ms , 100us, and 1us delays to do that i need to figure out what to replace nop's with below here (mainboard arduino uno r3 ATmega328 Thank you.
"delay_ms%=:    nop                 ; code to replace  nop  \n"
"delay_100us%=: nop                 ; code to replace  nop  \n"
"delay_1us%=:   nop                 ; code to replace nop  \n"
"               sbiw r30,1          ; decrement ms count (r31:r30)\n"
"               brne delay_ms%=     ; loop to delay_ms while > 0  \n"
"               ret                 ; return from subroutine      \n"
The rest is below.
word millisecs;
Serial.begin(9600);
void setup() asm volatile(
"          ldi r16,0x3F    ; r16 = 00111111\n"
"          out 4,r16       ; set pins 8-13 as outputs in DDRB\n"
::: "r16");
millisecs = 1000;            // 1s blink delay
Serial.begin(9600);
void loop()
long starttime = millis();        // make a note of the start time
asm volatile(
// jump to "blink" - ie jump around the delay_ms subroutine
"            rjmp  blink%=        ; relative jump to 'blink' \n"
::: "r16");
registers used:
r31 - millisecond count (lo byte)
r30 - millisecond count (hi byte)
r17 - 100 microsecond count
r16 - 1 microsecond count
Overall delay (ms) = r30:r31 * r17 * r16
Ignacio Vazquez-Abrams
  • 17,733
  • 28
AVR LibC already has macros that do this, provided F_CPU is set correctly.
// Note: The Arduino IDE gets the value for F_CPU from boards.txt
#define F_CPU xxxxxxxxxx
#include <util/delay.h>
_delay_ms(1);
_delay_us(100);
_delay_us(1);
  • 17,733
  • 28
