I am planing to build a project where an arduino pro mini 3.3V runs on 2 aa batteries. The standard brown out detection shuts it down at about 2.7/2.8V where it could run on lower voltages too. So I changed the efuse to get the BOD down to 1.8V. I connected a serial to usb converter and used avrdude:
avrdude -c avrisp -p m328p -P COM5 -b 19200 -U lfuse:w:0xff:m -U hfuse:w:0xda:m -U efuse:w:0x06:m
Then I tried to upload a program using the arduino 1.0.3 IDE but I got this error:
avrdude: stk500_getsync(): not in sync: resp=0x1c
With 1.6.4 I got another error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1c
After some googling I tried some lower baud rate (the standard seems to be 57600). With 19200 everything worked with avrdude, so I created a new entry in the boards.txt
pro328.name=Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328 BOD 1.8V
pro328.upload.protocol=arduino
pro328.upload.maximum_size=30720
pro328.upload.speed=19200
pro328.bootloader.low_fuses=0xFF
pro328.bootloader.high_fuses=0xDA
pro328.bootloader.extended_fuses=0x06
pro328.bootloader.path=atmega
pro328.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
pro328.bootloader.unlock_bits=0x3F
pro328.bootloader.lock_bits=0x0F
pro328.build.mcu=atmega328p
pro328.build.f_cpu=8000000L
pro328.build.core=arduino
pro328.build.variant=standard
And burned a bootloader using the 1.0.3 IDE again. After that I could upload a blink program. My goal is to upload a mysensors sketch though and that doesn't work. I am getting an error
avrdude: verification error, first mismatch at byte 0x0002
0x69 != 0x61
avrdude: verification error; content mismatch
Mysensors seems to have general problems with old arduino IDEs so I tried to use the newer 1.6.4 but I can't define my own board there and if I try it without I get hte out of sync error (because it's still using the wrong baudrate I guess).
I also tried using another arduino uno as ISP => same results
How can I fix this? Is there a way to define my own board for 1.6.x? Whats the standard way of doing this and why does the change of the efuse results in me not beeing able to program the mini any longer?
Thanks for every answer/help!
