I currently try to connect an Arduino Micro/Leonardo/32u4 to an ELM327 Bluetooth dongle using a HC-05 Bluetooth shield from iTeadStudio. I also have similar problems trying to connect to a bluetooth dongle (with added serial connection) on my PC.
The basic AT-command communication works, but I haven't found out yet why AT+PAIR or AT+LINK are failing and what should be done to avoid this (I've done dozens of Serial Monitor command iterations). Until now I haven't found a command sequence that reliably connects. What I've tried so far (from different documentation and example codes):
Check general AT command set:
AT
> OK
Reset to default values:
AT+ORGL
> OK
Set master mode and check it:
AT+ROLE=1
> OK
AT+ROLE?
> +ROLE:1
> OK
Connect only to the specified bluetooth address:
AT+CMODE=0
> OK
Reset and initialize:
AT+RESET
> OK
AT+INIT
> OK
Configure inquiring mode:
AT+INQM=1,9,48
> OK
Inquire:
AT+INQ
> +INQ:12:34:567890:1F1F,7FFF
> OK
AT+STATE?
> +STATE:INQUIRING
Try to stop inquiring:
AT+INQC
> OK
AT+STATE?
> +STATE:INQUIRING
> OK
Reset and initialize again (otherwise we can't leave the inquiring state):
AT+RESET
> OK
AT+INIT
> OK
AT+STATE?
> +STATE:INITIALIZED
> OK
Try to pair with the found device (my PC asks for the 1234-password and creates a serial port):
AT+PAIR=12,34,567890,20
> OK
AT+STATE?
> +STATE:PAIRED
Try to connect
AT+BIND=12,34,567890
> OK
AT+LINK=12,34,567890
> FAIL
Does someone have some hints for finding the right sequence?
Thomas S.
  • 566
I am using a "BIND" between the PAIR and LINK:
AT+PAIR=98D3,31,FC2D54,5
AT+BIND=98D3,31,FC2D54
AT+LINK=98D3,31,FC2D54
That seems to work for me.
See the docs here:
ftp://imall.iteadstudio.com/Modules/IM120723009/DS_IM120723009.pdf
Dan McCreary
  • 307
It looks like I now have a slight understanding of what happens and how to get the HC-05 working.
Be sure to have the CMD-DAT-switch set to CMD before turning on the HC-05.
Command mode (configuration)
AT
> OK
Reset to default values (sets, among others, ROLE=0 and CMODE=1):
AT+ORGL
> OK
AT+ROLE=1
> OK
AT+ROLE?
> +ROLE:1
> OK
Reset and initialize (reset aborts, e.g. the inquiring state - quickly flashing LED; without initializing you would get ERROR(16)):
AT+RESET
> OK
AT+INIT
> OK
Now the LED should slowly flash. Optionally: set password of the target device:
AT+PSWD=1234
> OK
Show count of all authenticated devices in pair list:
AT+ADCN?
> +ADCN:7
> OK
If the value is larger than 0, delete all authenticated devices in pair list:
AT+RMAAD
> OK
Now pair with the desired device (the last 20 mean 20s):
> OK
The LED starts flashing one time with a longer pause. Set the desired device:
> OK
Now link (e.g. when connecting to the ELM327; the PC will create another new port after having requested the password from the user):
> OK
The LED starts flashing two times with a longer pause. After linking, it might be that either the HC-05 switches to data-mode or continues in command-mode (haven't found out when it does one or the other).
Command mode (auto connect)
Now switch off the HC-05 and keep the CMD-DAT-switch to CMD. Switch it on again. It should automatically connect to the previously connected device. To switch to the data mode, first disconnect...
AT+DISC
> +DISC:SUCCESS
> OK
... and reconnect.
> OK
Now the connection seems to have switched to data mode.
Data Mode
Now switch off the HC-05 and move the CMD-DAT-switch to DAT. Turn on the HC-05. It automatically will try to connect to the previously connected device - the LED should flash two times with longer pause - and you don't have to mess with HC-05-AT commands any more.
Thomas S.
  • 566
