I am trying to control a dc motor speed with PWM. When I test it with simple program like spin in one direction with set PWM value it works. If PWM>70 the motor will start spinning and max is 255.
But when I try to do the same in code below it only spins if PWM value is 255. Can someone help me?
test.ino
// encoders
//motor_encoder
int encoder0PinA = 3;
int encoder0PinB=2;
volatile int encoder0Count = 0;
volatile float angle0 = 0;
volatile float velocity0 = 0;
volatile float angle0_previous = 0;
volatile float angle0_post = 0;
//pendulum_encoder
int encoder1PinA = 20;
int encoder1PinB = 21;
volatile int encoder1Count = 0;
volatile float angle1 = 0;
volatile float velocity1 = 0;
volatile float angle1_previous = 0;
volatile float angle1_post = 0;
float error=0;
// motor
int enA = 10;
int in1 = 9;
int in2 = 8;
// for Timer2
volatile int tcnt2 = 131;
volatile int t = 0;
volatile float error_proportional = 0;
volatile float error_derivative = 0;
volatile float error_integral = 0;
float kp =50;
float kd = 0;
float ki = 0;
float u = 0;
float motor_input = 0;
int INPUT_MAX = 255;
int P=0;
int I=0;
int D=0;
int integral=0;
void setup()
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
// for encoder
// for encoder 0
pinMode(encoder0PinA, INPUT);
pinMode(encoder0PinB, INPUT);
attachInterrupt(0, doEncoder0A, CHANGE);
attachInterrupt(1, doEncoder0B, CHANGE);
// for encoder 1
pinMode(encoder1PinA, INPUT);
pinMode(encoder1PinB, INPUT);
attachInterrupt(2, doEncoder1A, CHANGE);
attachInterrupt(3, doEncoder1B, CHANGE);
// for Timer2
// interrupts every 1 ms
TIMSK2 &= ~(1<<TOIE2);
TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
TCCR2B &= ~(1<<WGM22);
ASSR &= ~(1<<AS2);
TIMSK2 &= ~(1<<OCIE2A);
TCCR2B |= (1<<CS22) | (1<<CS20);
TCCR2B &= ~(1<<CS21);
TCNT2 = tcnt2;
TIMSK2 |= (1<<TOIE2);
Serial.begin (9600); // for debugging
void loop()
error = angle1;
if (abs(error) < 2){
integral = integral + error;
else {
integral=0;
P = error*kp;
I = integral*ki;
D = (angle1_previous-angle1)*kd;
u = P + I + D;
motor_input = 255/24 * u;
Serial.print("u: ");
Serial.print( u);
Serial.print(" ");
motor_input = (int)motor_input;
if (motor_input >= INPUT_MAX){
motor_input = INPUT_MAX;
else if (motor_input <= -INPUT_MAX){
motor_input = -INPUT_MAX;
Serial.print("error_proportional: ");
Serial.print(error_proportional);
Serial.print(" ");
Serial.print("error_derivative: ");
Serial.print(error_derivative);
Serial.print(" ");
Serial.print("error_integral: ");
Serial.print(error_integral);
Serial.print(" ");
Serial.print("motor_input: ");
Serial.println(motor_input);
setMotorSpeed(motor_input);
measure_states.ino
// enkoder od motora
void doEncoder0A(){
if (digitalRead(encoder0PinA) == HIGH) {
if (digitalRead(encoder0PinB) == LOW) {
encoder0Count = encoder0Count + 1;
else {
encoder0Count = encoder0Count - 1;
else {
if (digitalRead(encoder0PinB) == HIGH) {
else {
angle0 = 0.000785*encoder0Count; // radian (2*pi/8000)
void doEncoder0B(){ // interrupt 1 function
else {
else {
if (digitalRead(encoder0PinA) == LOW) {
else {
// for encoder 1
void doEncoder1A(){
if (digitalRead(encoder1PinA) == HIGH) {
if (digitalRead(encoder1PinB) == LOW) {
encoder1Count = encoder1Count + 1;
else {
encoder1Count = encoder1Count - 1;
else {
if (digitalRead(encoder1PinB) == HIGH) {
else {
angle1 = 0.000785*encoder1Count;
void doEncoder1B(){
else {
else {
if (digitalRead(encoder1PinA) == LOW) {
else {
ISR(TIMER2_OVF_vect) {
TCNT2 = tcnt2;
t++;
// estimate velocity
if (t == 1){
angle0_previous = angle0;
angle1_previous = angle1;
else if (t == 20){
angle0_post = angle0;
angle1_post = angle1;
else if (t == 21){
velocity0 = (angle0_post - angle0_previous)*50; // rad/s
velocity1 = (angle1_post - angle1_previous)*50;
error_proportional = 3.1416 - angle1;
error_derivative = 3.1416 - velocity1;
error_integral = error_integral + error_proportional;
t = 0;
motor.ino
void setMotorSpeed(int speed)
if (speed < 0)
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
else
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
analogWrite(enA,abs(speed));
angle1_previous=angle1;
UPDATE 1:
I found that the code below for setting timer messes PWM but Im not sure why. Anyone have any idea?
ASSR &= ~(1<<AS2);
TCNT2 = tcnt2;
