I am building a quad-copter, the problem is of stability and for better stability lesser sampling time is required. For lesser sampling time I need to have faster loop() function. But the Pulsein() command takes very large time which in turn expands the sampling time. Is there any method to read the rc channels in background and read them from an integer.
The keyword you are looking for here is interrupt. What is a pulse but a signal that goes from low to high followed by going from high to low, with some period of time between them?
Instead of sitting there waiting for the pulse to arrive then measuring how long it is, which is essentially what pulseIn() does, you need to attach the signal to an interrupt pin. Then you write an interrupt routine that triggers when the signal changes from one level to another which looks to see what the level actually is.
If the signal has risen from low to high then you record the time it happened. If the signal has fallen from high to low then you look what the time is, and subtract the time you remembered from when the signal rose. That difference is then the width of the pulse, which you can store in an integer to read in your main loop.
If you have a number of signals you want to monitor you might want to look into using the pin change interrupt which allows you to use any pin as an interrupt source.
- 105,851
- 5
- 82
- 139
You may find my answer to another question – Read RC receiver channels using Interrupt instead of PulseIn – useful. It includes the sketch shown below, which is intended for background timing of four RC channels attached to pins A0-A3. See the other answer for further comments about the code, example output, etc.
/* rcTiming.ino -- JW, 30 November 2015 --
* Uses pin-change interrupts on A0-A4 to time RC pulses
* Ref: https://arduino.stackexchange.com/questions/18183/read-rc-receiver-channels-using-interrupt-instead-of-pulsein
#include <Streaming.h>
static byte rcOld; // Prev. states of inputs
volatile unsigned long rcRises[4]; // times of prev. rising edges
volatile unsigned long rcTimes[4]; // recent pulse lengths
volatile unsigned int rcChange=0; // Change-counter
// Be sure to call setup_rcTiming() from setup()
void setup_rcTiming() {
rcOld = 0;
pinMode(A0, INPUT); // pin 14, A0, PC0, for pin-change interrupt
pinMode(A1, INPUT); // pin 15, A1, PC1, for pin-change interrupt
pinMode(A2, INPUT);
pinMode(A3, INPUT);
PCMSK1 |= 0x0F; // Four-bit mask for four channels
PCIFR |= 0x02; // clear pin-change interrupts if any
PCICR |= 0x02; // enable pin-change interrupts
// Define the service routine for PCI vector 1
ISR(PCINT1_vect) {
byte rcNew = PINC & 15; // Get low 4 bits, A0-A3
byte changes = rcNew^rcOld; // Notice changed bits
byte channel = 0;
unsigned long now = micros(); // micros() is ok in int routine
while (changes) {
if ((changes & 1)) { // Did current channel change?
if ((rcNew & (1<<channel))) { // Check rising edge
rcRises[channel] = now; // Is rising edge
} else { // Is falling edge
rcTimes[channel] = now-rcRises[channel];
changes >>= 1; // shift out the done bit
++channel;
++rcChange;
rcOld = rcNew; // Save new state
Serial.begin(115200);
Serial.println("Starting RC Timing Test");
setup_rcTiming();
unsigned long rcT[4]; // copy of recent pulse lengths
unsigned int rcN;
if (rcChange) {
// Data is subject to races if interrupted, so off interrupts
cli(); // Disable interrupts
rcN = rcChange;
rcChange = 0; // Zero the change counter
rcT[0] = rcTimes[0];
rcT[1] = rcTimes[1];
rcT[2] = rcTimes[2];
rcT[3] = rcTimes[3];
sei(); // reenable interrupts
Serial << "t=" << millis() << " " << rcT[0] << " " << rcT[1]
<< " " << rcT[2] << " " << rcT[3] << " " << rcN << endl;
- 8,920
- 3
- 21
- 33
