I wonder if it is possible to send a value from one arduino to another.
Basically, I have one arduino measuring let's say weight, but I want to display that value using an lcd in another arduino. Is it possible to send the value to a pin using analogwrite or digital write in the arduino doing the measurement and use analogread/digitalread at the other arduino making the display?
I do not know if this is possible but what is attractive is that one can have several arduino making weight measurements, all showing up in the display of just one central one...
Camilo
  • 359
You could have the LCD Arduino be an I2C master and all the weighing Arduinos be slaves. There's an example of master/slave communication and wiring here: https://www.arduino.cc/en/Tutorial/MasterReader.
I2C supports up to 128 devices and the wiring is very simple.
Hans Kilian
  • 156
Yes it is possible,The answer provides one of the basic methods to do so
Connections
   Arduino1          Arduino2
     TX--------------->RX
     RX--------------->TX
Arduino1 Sketch:
void setup(){
 Serial.begin(9600);
 delay(2000);
 ////read sensor data to a variable
 Serial.println(sensorDataVariable);
 delay(2000); //Not to flood serial port
Arduino2 Sketch :
int byteRead;
void setup(){
 Serial.begin(9600);
 delay(2000);
  /* check if data has been sent from the computer: */
  while (Serial.available()) {
    /* read the most recent byte */
    byteRead = Serial.read(); //now byteRead will have latest sensor
                              // data sent from Arduino1
  //Write code to display the values to LCD
hope this helps
TheGejr
Lokanath
  • 167
To tie multiple Arduinos together you need to come up with some kind of networking topology and some form of networking protocol.
Requirements are:
  1. The Arduinos must not (electrically) interfere with each other
  2. There must be some way to know which Arduino is sending what and where to
The two points could be addressed by having a separate connection for each Arduino but that ends up complicated, and there are only limited resources on an Arduino for creating such connections (you really need to use the hardware UART ports and the Uno has only 1. The Mega has 4).
A better solution is to use a bus system (also known as a multi-drop network). There are a number of existing and well supported methods for doing this. In the automotive system the CAN Bus is used. In industry the RS-485 system is heavily used.
Personally I prefer RS-485 since it is well established. There are a number of standard protocols that run on RS-485, such as MODBUS, but for the Arduino world I wrote my own light weight protocol specially which is far simpler to get going with. You can find out more here: https://github.com/MajenkoLibraries/ICSC
Majenko
  • 105,851
  • 82
  • 139
