I have two NRF24L01+ modules which are transceivers, but for my project I would like to send a very simple signal from one of these modules to the be read by the other.
That would've been very simple if I had an Arduino on each side but due to power consumption constraints as well as size, cost and practicality, the transmitting side won't have one. Would it still be possible to do this?
To clarify, the message itself is not important and can be set in stone, it will never change. I really just want to detect on the receiving side (which will have an Arduino) that the transmitter is in fact transmitting. Transmission will be triggered by a push-button.
Ideally I would have a way of identifying my particular transmitter from others on similar frequencies but I am not too precious about that.
Ricardo
  • 3,390
  • 26
  • 55
Ceottaki
  • 173
5 Answers5
The nRF24L01+ has a somewhat complex SPI based interface, where many registers have to be configured and tested and timeouts honored. Therefore it requires some kind of microcontroller to send or receive even the simplest message.
This can be as simple as a 3.3v Arduino Pro Mini (less than $3 with shipping), and there are libraries which simplify the task of interfacing to it - in particular see the RF24 library (there are many variations, see https://github.com/TMRh20/RF24 for a good one).
But many other microcontrollers could work as well.
Once you bite the bullet and accept the need for a microcontroller, yes the code can identify the source of the signal (which pushbutton) and much, much more.
Or you could use a dedicated device like an xBee which can be configured using a Windows utility to send the state of an input pin to another xBee; basically there is already a programmed microcontroller on the module along with the radio (not nRF24L01+ compatible).
Zeph
  • 445
Note, there is also the NRF24LE1 SoC which has its own ULP MCU - good for transmitting simple data such as sensor readings. If used to Arduino, ARduino Pro Mini 3.3v and the NRF24L01+ is easier and better way to go. (Mod the Arduino to be ULP)
Dannz
An ATTiny85 can drive the NRF24L01+: "nrf24l01+ control with 3 ATtiny85 pins"
At least this is not a "full" Arduino...
Edit 2015-06-06:
Hackaday News: "EMBED WITH ELLIOT: MULTIPLEXING SPI USES FEW PINS"
The referred blog entry is: "nRF24l01 control with 2 MCU pins using time-division duplexed SPI".
(-: Nice countdown... 3 pins, 2 pins, ... ;-)
gone
  • 354
The nRF24L01+ needs an external microcontroller to be used.
I believe an XBee could be used if you want a "single module" solution, however using even the Atmega328p (standard for Arduino Uno) would probably be cheaper than this.
1) Easy way
This transmitter uses only SPI interface so you need to drive it some logic unit, i.e. microcontroller that supports this interface (i.e. AVR atmega8) and is able to use driver for this module as a ready to use set of high level functions to express your intentions in your code.
2) Badly bad way
You can use the SPI to I2C converter as well. Connect it to your computer via serial port - but note that it's a big effort. You will need to port nRF24L01 driver, etc.
http://www.elecrow.com/nrf24l01-wireless-shield-spi-to-i2c-interface-for-arduino-p-737.html
soerium
  • 159
