I'm having a problem with the intel galileo gen2 ethernet. I am trying to get a webpage, but I can only connect to the ethernet, not the webpage.
I get this in the Serial monitor:
My code:
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x98, 0x4f, 0xee, 0x01, 0x8d, 0xdf };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
IPAddress server(216, 58, 217, 206); // numeric IP for Google (no DNS)
//char server[] = "www.google.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
IPAddress dns(192, 168, 1, 122);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
// wait for serial port to connect. Needed for Leonardo only
delay(5000);
// start the Ethernet connection:
Ethernet.begin(mac, ip, dns, gateway, subnet);
Serial.println("connected to ethernet");
// give the Ethernet shield a second to initialize:
delay(1000);
Serial.println("connecting...");
// if you get a connection, report back via serial:
int ch = client.connect(server, 80);
if (ch) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.print("connection failed, error code ");
Serial.println(ch);
void loop()
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
Any help is greatly appreciated.
