I have got a String filled up with 0 and 1 and would like to get an Integer out of it:
String bitString = "";
int Number;
int tmp;
bitString = "";
  for (i=1;i<=10;i++)
    tmp= analogRead (A0);
    bitString +=  tmp % 2;
    delay(50);
// now bitString contains for example "10100110"
// Number = bitstring to int <-------------
// In the end I want that the variable Number contains the integer 166
kimliv
  • 561
If you only need the string for printing you can store value in an integer and then use the Serial.print(number,BIN) function to format the output as a binary value. Appending integers to strings is a potentially costly operation both in performance and memory usage.
int Number = 0;
int tmp;
for (int i=9;i>=0;i--) {
  tmp = analogRead (A0);
  Number += (tmp % 2) << i;
  delay(50);
Serial.print(Number, BIN);
Craig
  • 2,120
Check out strtoul()
It should work something like this:
unsigned long result = strtoul(bitstring.c_str(), NULL, 2);
Now you have a long variable which can be converted into an int if needed.
Doowybbob
  • 201
