From the Arduino reference on AnalogRead:
"It takes about 100 microseconds (0.0001 s) to read an analog input, so the maximum reading rate is about 10,000 times a second."
500msps is an awfully high rate - my first instinct is, perhaps you need to revisit what you are after, and why.
There are indeed chips that will do this for you. It is still not possible with an Arduino, since the Arduino can't even receive the data this fast, let alone process it. Assuming 8-bit sampling, this would generate a stream of data at 4gigabits/second - I doubt any disk drive could write that fast (SATA3 is 4.8gbit/sec, which is 20% more, I suspect that the 20% would be eaten up by overhead - you can't just send raw data to a drive, you also have to tell it where to put it. That just accounts for getting the data to the drive circuitry, not actually storing it).
Perhaps what you're looking for is an oscilloscope. An oscilloscope takes high speed readings and displays them. Oscilloscopes are often used for testing circuits (e.g. looking at what an Arduino puts out/reads in when it's being programmed). Looking on National Instruments' websites, their cheapest one I could find that does > 500msps is worth about US$8,000 (ballpark). You will still not be able to store this to disk, or process it in any meaningful way, in realtime - a board like this will typically capture data (based on a trigger, sample until the memory is full, then slowly move the data to the PC to process.
