I have two XBee's connected to two Arduino Uno boards (one for each XBee). I connected each XBee to the X-CTU software, and have set the following:
XBee 1
Pan ID = 4270 DL = 10 MY = 20
XBee 2
Pan ID = 4270 DL = 20 MY = 10
Both
DD = 10000 IC = FF IR = 32
Therefore, they should be on the same network and see each other as the 'other person' each is talking to. I'm using the TX and RX pins of the arduino and the XBee to communicate over the serial port.
When testing if each can hear the other, I loaded one arduino with this code:
#include <SPI.h>
  Serial.begin(9600);
// put your main code here, to run repeatedly:
  Serial.print('x');
  delay(1000);
Then another with this:
#include <SPI.h>
  Serial.begin(9600);
  pinMode(7,OUTPUT);
  digitalWrite(7,LOW);
  if(Serial.available())
    char getData = Serial.read();
    if(getData == 'x')
      digitalWrite(7,HIGH);
      delay(500);
      delay(500);
  Serial.print(getData);
  getData = ' ';
This works perfectly. One LED will light up on the correct arduino in half second intervals. However, when I try to make them both communicate at the same time to each other, nothing happens. Neither LED will light up. The code for both arduino's is:
#include <SPI.h>
  Serial.begin(9600);
  pinMode(7,OUTPUT);
  Serial.print('x');
  delay(1000);
      if(getData == 'y')
        delay(500);
        delay(500);
      getData = ' ';
But for one arduino I change the code to Serial.print('y') and if(getData == 'x') to listen for the other one. I also have tried delaying one arduino in the setup by one second to offset the sending and recieving, but that also doesn't help.
I need them to be able to listen and talk to each other, maybe even at the same time like this example. I'm trying to create a proximity sensor in, lets say the 'back', area communicate with the 'front' area, and an accelerometer and two switches from the 'front' communicate with the 'back'.
Is there any settings I can change in X-CTU, such as the baud rate or the amount of packets re-sent, to overcome this problem? Or is this merely a code issue?
I do have the power connected to the 3.3V pin of the arduino, and I'm using 470/220 Ohm resistors as voltage dividers for the output pins from the arduino to the XBee, so I don't think voltage is an issue here.
Also, I have disconnected the arduino from the computer. I'm powering it via the USB-A to USB-B cord -> 13000 mAh 5V DC rechargeable battery, so there should be no interference with the serial data lines. Pin 2 (RX) of the XBee is connected to pin D0 (RX) of the arduino, and pin 3 (TX) of the XBee is connected to pin D1 (TX) of the arduino.
Thanks for your help.
Did you set one of your modules into coordinator mode? Every xBee network needs a coordinator. Therefore, you need to put one of your Xbee modules into coordinator mode using the "Function Set" dropdown box in X-CTU. The coordinator has the fixed address 0, so you need to set DL and HL address parts of the other module to 0. On your coordinator, you can set DL to FFFF and HL to 0, which is the broadcast address.
Softserial won't help you. It's just a way to use some of the pins as an additional serial port. Don't use that if you can use a hardware serial port.
