How do I store floats in flash and how do I read them from there? (I need a look-up table for pairs of float values.)
The storing part doesn't seem to be so difficult as this compiles:
PROGMEM float value1 = 1.23456;
But how do I read them? Do I need to copy them byte by byte to a float variable, or is there a better way? (I am using an Arduino ATmega 328p with 4-byte floats.)
fuenfundachtzig
  • 1,535
  • 26
There is a helper macro in avr-libc that is designed just for this purpose:
#define pgm_read_float_near(address_short) __LPM_float((uint16_t)(address_short))
Read a float from the program space with a 16-bit (near) address.
Note
    The address is a byte address. The address is in the program space.
Use it like:
PROGMEM float pi=3.141592653;  // constant value in flash
float diameter = 24.332154;    // variable user value
float circumference = diameter * pgm_read_float_near(&pi);
Majenko
  • 105,851
  • 82
  • 139
I realize that the OP asked about a single value, but I thought I'd add info on retrieving from an array.
const float pmdata[] PROGMEM = {1.0, 2.0, 3.0};
then retrieve thusly:
float val = pgm_read_float(&pmdata[idx]);
dlchambers
  • 131
