Windows 7 here. I just bought an Arduino Due and downloaded the Arduino IDE. I wrote a simple "blink LED" program (see below) and am trying to flash it to the Due.
When I connected the Due to my laptop (via micro USB cable), I got a warning on my laptop that it could not find the correct device driver. So I followed the instructions discussed on this excellent video tutorial and went into Control Panel >> System >> Device Manager >> Arduino and pointed it to load the appropriate device driver from C:\Program Files (x86)\Arduino\drivers. This got rid of the warning. Hooray!
I then Verified & Compiled my program:
int led = 13;
pinMode(led, OUTPUT);
digitalWrite(led, HIGH);
delay(5000);
digitalWrite(led, LOW);
delay(5000);
Great success! Now it was time for me to upload the program to my Due. The first time I tried to upload it, I got the following error:
Arduino: 1.6.4 (Windows 7), Board: "Arduino Uno"
Sketch uses 1,068 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 11 bytes (0%) of dynamic memory, leaving 2,037 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\\.\COM1": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
So then in the IDE I went to Tools >> Port and changed the selection from Serial to COM3 (again, sort of explained in that video tutorial). I tried to upload again:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x09
I thought it was interesting that the IDE thinks this is an Arduino Uno. So then I went to Tools >> Board and changed the selection from Uno to Duemilanove, hoping that Due and Duemilanove are compatible for the programmer/flasher tool. This time the error was the same as last, except the first line reads:
Arduino: 1.6.4 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328"
So at least the IDE is switching board correctly. :-) I should note that my Tools >> Board menu does not have an "Arduino Due" option. And when I go to Tools >> Board >> Board Manager, searching for Due does not turn up anything either.
I also tried running the upload with verbose output, but that really didn't tell me anything more. I'm happy to post the exact verbose output but figured I could omit it here for brevity. I also did peruse the troubleshooting link that the error output recommends, but it looks like I've already exhausted all of those recommendations as well.
I'm stuck and frustrated, any suggestions?
What do I need to do to get the IDE programming my Due?
