Few days ago, I built my own custom Arduino on the breadboard. It is built according to tutorial on http://www.crash-bang.com/resource/breadboard-arduino/. The Atmega328P-PU is already burned with the Arduino bootloader with simple blink sketch.
For the programmer, I decided to use the Arduino USB2Serial. Again, it is connected as shown on crash-bang site. Problem is I get this error when uploading a different sketch:
avrdude -Cavrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:build244630154737317489.tmp/sketch_may23a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
     Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
     Copyright (c) 2007-2009 Joerg Wunsch
     System wide configuration file is "avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 4.4
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "build244630154737317489.tmp/sketch_may23a.cpp.hex"
avrdude: writing flash (450 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
Most of the time I do not even get to this point and just end up with something like:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf5
What I have done so far:
  • I already tried to reset Arduino just before uploading the sketch.
  • According to the avrdude, bootloader is fine.
  • Reinstalled drivers, Arduino IDE
  • Changed the USB cable and connected it to another USB slot
  • Burned new bootloader using ArduinoISP
Thank you for help.
Lorin
  • 131
"Step 3 says to connect +ve rail –> AVCC (pin 20) and +ve rail –> AREF (pin 21). You can leave those pins not connected. "
+ve rail should not be connected to Aref. The +ve rail will connect via the internal operation of the ADC mux.
AVCC and both Gnds should be connected per the datasheet: 5.2.7. AVCC AVCC is the supply voltage pin for the A/D Converter, PC[3:0], and PE[3:2]. It should be externally connected to VCC, even if the ADC is not used.
28.2. AVCC must not differ more than ±0.3V from VCC.... Optionally, AVCC or an internal 1.1V reference voltage may be connected to the AREF pin by writing to the REFSn bits in the ADMUX Register. The internal voltage reference must be decoupled by an external capacitor at the AREF pin to improve noise immunity.
If you connect Aref to the +ve rail externally, and then select the internal reference, things can go bad.
FTDT thru 0.1uF cap to Reset, with 10K pullup, and reverse biased diode to VCC, works for me in plenty of designs. Not sure why it does not work in all cases. The diode dissipates any spike on the Reset line to keep the chip from thinking high voltage programming mode is being started.
CrossRoads
  • 2,449
