Is it possible to send OTA updates to Arduino via nRF24L01+ module?
Here are my findings:
Here is an instructable explaining how to program Arduino wirelessly but this thing uses a BT module which shows up on PC as a COM port.
Here is something similar using Xbees.
However, these use another arduino attached to a PC on the other end. In my case, I am planning to use rPi hooked to another nRF24L01+ rather than PC.
This is an excerpt from the datasheet of Atmega chip:
In ATmega88A/88PA/168A/168PA/328/328P the Boot LoaderSupport provides a real Read-While-Write SelfProgramming mechanism for downloading and uploading program code by the MCU itself. This feature allows flexible application software updates controlled by the MCU using a Flash-resident Boot Loader program. The Boot Loader program can use any available data interface and associated protocol to read code and write (program) that code into the Flash memory, or readthe code from the program memory.
Here is what I planned as a strategy.
Master programmer = Raspberry Pi + nRF module.
Slave arduino = Arduino + nRF24L01 + external EEPROM
Once I have to upload a new code, I can transmit the compiled code to the arduino (I can do that, right?) and Arduino will save it in the external EEPROM for the time being.
When the transfer is complete, I will send a signal which will make the arduino reset and copy the code from EEPROM to its flash memory.
My questions:
Is the strategy correct and feasible?
How should I proceed to achieve it?
Any other suggestions which you might have are welcome.
Whiskeyjack
  • 247
5 Answers5
Your best strategy would be to write your own bootloader.
The existing bootloader receives data through the serial port and writes it, a page at a time, to the flash. Your custom bootloader, instead, would receive the data through the nRF module and write it to flash, a page at a time.
You could use the source code for the existing bootloader (maybe use optiboot?) as a starting point and remove the UART code, replacing it with nRF code.
Of course, you still need a way to enter the bootloader when you want to program it - the easiest way is to ensure that is added into any sketch you upload so you can send an instruction to that sketch to enter the bootloader.
You would also need to create a program on the Pi to do the programming over the air - or modify an existing one like avrdude.
It may, in the long run, be simpler to have a pair of other Arduinos (maybe something small like an ATTiny based board) to act as bridges between UART and the nRF modules so they become a transparent wireless serial link.
Majenko
  • 105,851
  • 82
  • 139
There is an Arduino optiboot fork for this now, which seems to handle what you want.
You would use a PC, RPi or whatever that could run avrdude to send the update to an Arduino acting as the update server, which transmits the code to the client.
The instructions on the page seem quite comprehensive.
Greenonline
  • 3,152
  • 36
  • 48
Kurt
  • 41
If you're working with remote sensor nodes, perhaps consider the MySensors library.
It's got support for two methods of delivering OTA updates - one using a node.js controller running on a rPi; and another third-party solution with a .NET front-end.
Failing that, you could borrow the bootloader code from the library and customise to your own needs.
pdey
It's definitely feasible and it's been done. Look at Low Power Labs site where Felix did the same thing, but with a RF69 radio and an external flash chip. You do need a modified bootloader as he uses, one that would detect the new sketch in the external flash and will upload it to the Arduino on reset. Radio difference aside this should work well for your purposes.
Given the flaky nature of the radio communication I think it's a good idea to store the program separately rather than create a highly modified bootloader which will read the radio stream - it might be that for programming you need a constant stream of bytes which the radio can't always provide (though I'm not 100% sure about this); another reason being that the extra code you would need to access the radio will make for a larger bootloader.
rslite
  • 413
As per @Majenko and @Kurt suggestions:
Please check out me blog post, it is exactly about that!
https://www.2bitornot2bit.com/blog/arduino-bootloader-with-ota-over-the-air-support-over-nrf24l01
I have made a complete tutorial about this issue and also modified the suggested code above so debugging will be easier.
The basic idea is to have a local station which forwards the new sketch from the computer->uart->spi->rf24 to a remote Arduino running a custom bootloader which listens on the rf24->spi instead of the UART. This bootloader does everything as usual (expecting protocol commands as part of the stk500 protocol and so on) but, instead of getting them over UART the packets arrive from the RF24 module through SPI.
During boot, the bootloader will have to initialize the RF module registers and then parse the incoming bytes if any; after a timeout, it will quit and run the sketch currently there in a loog as usual
In my blog you will see some notes about the Hardware configuration for the local station: you need a 10uF capacitor between the RESET and GND pins to avoid flashing the local station while trying to flash the remote station.
That post also incldues the commands needed to use AVRdude to flash the bootloader and then to flash the remote station (which has the new bootlaoder) through the local station running the "flasher" sketch (station with the capacitor).
Basic commands are:
avrdude -C "C:\Users\Ben\Downloads\avrdude\etc\avrdude.conf" -b 19200 -c usbtiny -p m328p -v -e -U efuse:w:0xFD:m -U hfuse:w:0xDA:m -U lfuse:w:0xFF:m -F
avrdude -C "C:\Users\Ben\Downloads\avrdude\etc\avrdude.conf" -b 19200 -c usbtiny -p m328p -v -e -U flash:w:optiboot_atmega328_new_bootlader.hex -U lock:w:0x0F:m
You can find the code on my blog and links to other sources and tools needed (such as an AVR programmer).
user1748502
  • 134
