I really hope somebody can help me.
I need help making my code receive updates faster to the parser...I need the received GPS coordinates (Latitude and Longitude) to update 5 or more times a second, currently it locks when stationary. Can somebody help?
code:
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
TinyGPS gps;
//SoftwareSerial ss(4, 3);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
//double getCurrentLatitude();
//double getCurrentLongitude();
//double cLatitude = 0.0;
//double cLongitude = 0.0;
//double getCurrentLatitude(){
// return cLatitude;
//double getCurrentLongitude(){
// return cLongitude;
void setup()
Serial.begin(115200);
// Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
// Serial.println();
// Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
// Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
// Serial.println("------------------------------------------------------------------------------------------------------------------------------------------");
Serial1.begin(9600);
void loop()
double flat, flon = 0.0000000000000;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
//static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
// print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
// print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
// gps.f_get_position(&cLatitude,&cLongitude, &age);
//print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 13, 8);
//print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 13, 8);
float lati = (float)flat;
float longi = (float)flon;
Serial.print(" ");
Serial.print(lati, 8);
Serial.print(" ");
Serial.print(longi, 8);
smartdelay(0);
//cLatitude = flat;
//cLongitude = flon;
// print_float(getCurrentLatitude(), TinyGPS::GPS_INVALID_F_ANGLE, 13, 8);
// print_float(getCurrentLongitude(), TinyGPS::GPS_INVALID_F_ANGLE, 13, 8);
// print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
// print_date(gps);
// print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 7, 2);
// print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
// print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
// print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
// print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0xFFFFFFFF : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
// print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? TinyGPS::GPS_INVALID_F_ANGLE : TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
// print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
// gps.stats(&chars, &sentences, &failed);
// print_int(chars, 0xFFFFFFFF, 6);
// print_int(sentences, 0xFFFFFFFF, 10);
// print_int(failed, 0xFFFFFFFF, 9);
Serial.println();
smartdelay(1000);
unsigned long start = millis();
do
while (Serial1.available())
gps.encode(Serial1.read());
} while (millis() - start < ms);
if (val == invalid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
else
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartdelay(0);
If data is invalid, print out *******
otherwise print out buffer
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
else
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
smartdelay(0);
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age == TinyGPS::GPS_INVALID_AGE)
Serial.print("********** ******** ");
else
char sz[32];
sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
month, day, year, hour, minute, second);
Serial.print(sz);
smartdelay(0);
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
smartdelay(0);
