I want to convert a string into a int value. in my real code, I receive a string "Slider 255" the number after slider changes from 0 to 255, so I want a int value to be equal to that number. This is a small example of the code:
#include <Servo.h>
Servo myServo;
int val = 0;
String s = "";
  Serial.begin(9600);
  myServo.attach(9);
  while(BT.available() >0){
  s =  Serial.read(); // which wiil be a number between 0 and 255
  // So I want val to be = to ehatever the string is. So far I have try this but it doesn´t work.
  // first attempt # 1
  val = s:
  myServo.write(val);
  // Second attempt # 2
  Serial.println(s)
  val = Serial.read();
   myServo.write(val);
BrettFolkins
  • 4,441
  • 26
Diego MEstre
The easiest way is to use the parseInt method available to Serial like this
int val = Serial.parseInt()
But, you will have to be sure that the non-number part of the message ("Slider") has already been dealt with.
You could also put the data into an arduino String Object and use it's toInt method, or put it in a C style string and use the atoi method.
BrettFolkins
  • 4,441
  • 26
