For doing some experiments I bootloaded an Atmega16a with Arduino Uno. I am powering my Atmega16a from Arduino UNO. I am not using any external clock. Atmega16a is connected to a breadboard. For bootloading I refer the site http://hardwarefun.com/tutorials/use-arduino-as-an-isp-programmer-to-program-non-arduino-avr-microcontrollers I can run blink sketch on my Atmega16a using Arduino as ISP. TX and RX of Atmega16 is connected to Max485's DI and RO respectively.
Atmega16a pin 14 (RXD) -> MAX485 pin 1-RO
Atmega16a pin 15 (TXD) -> MAX485 pin 4-DI
Atmega16a pin 17 (D3) -> MAX485 pin 2 and 3. Also connects a LED to the pin
I used a boards.txt downloaded from https://github.com/sudar/arduino-extra-cores/blob/master/boards.txt
Issue: hang at Serial.println
I faced issues when I started to interface with MAX485.
The program wont run if I add a Serial.println, see my program below.
Serial.begin(76800); // I tried 9600 too
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
delay(400);
Serial.println("20"); //comment this code and could see the led blinks
delay(2000);
digitalWrite(3, LOW);
delay(400);
Regression
I tried Latest Arduino IDE as well as 1.0.6 version
I could do a serial communication with Raspberrypi and Arduino Uno via MAX485 without any issues. For the complete connection detail of MAX485 and other Arduino, check my blog.
Some times I receive some string to serial port of Raspberry pi like below. I run a nodejs app in RPi, using serialport npm and parser is RAW.
<Buffer fa>
<Buffer 82>
<Buffer 86 ff>
<Buffer fe>
<Buffer fe>
How to prevent these hangs?
