I tried to connect my Raspberry Pi with the Huawei Surfstick. All the tutorials i watched so far didn't helped me. If i plug in the Surfstick the raspberry shows that it is associated with it and has an ip. But when i try to open a website like google it says website cant be reached. I followed some other tutorials and my /etc/network/interface looks different. There is only a path to
source-directory /etc/network/interfaces.d another unusual thing is that if i type in the command route it says:
link-local 0.0.0.0 255.255.0.0 U 205 0 0 wwan0
and the default option is all 0. Some Tutorials also say that i have to download wvdial or sakis3g or ppp to connect to the surfstick but im unable to download these files: it says the packages are not available and they cannot be found. Does anybody has a solution to these problems? Thank you for the support and sorry for bad english.
edit: if i type ip a it shows:
4: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
link/ether d6:49:e3:08:53:42 brd ff:ff:ff:ff:ff:ff
inet6 fe80::4fdf:4ab6:ebf4:be67/64 scope link
i also tried to ping to 8.8.8.8 or www.google.de but it also didn't help it says "unknown Host".
edit 2.0:
if i type in the command route it shows:
pi@raspberrypi:~ $ route<br>
Kernel-IP-Routentabelle<br>
Ziel --------Router --- Genmask -- Flags--- Metric Ref Use Iface<br>
default -- 0.0.0.0 ----- 0.0.0.0 ------- U ------- 204 ---0 --- 0 --wwan0
<br>link-local 0.0.0.0 --- 255.255.0.0 ---U --------204 -- 0 ---- 0 --wwan0
<br></brodcast>
edit3.0:
when typing: ip show route:
default dev wwan0 proto kernel scope link src 169.254.2.14 metric 204
169.254.0.0/16 dev wwan0 proto kernel scope link src 169.254.2.14 metric 204<br></brodcast>
and ip addr show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000<br>
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00<br>
inet 127.0.0.1/8 scope host lo<br>
valid_lft forever preferred_lft forever<br>
inet6 ::1/128 scope host <br>
valid_lft forever preferred_lft forever<br><br>
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000<br>
link/ether b8:27:eb:cc:4b:80 brd ff:ff:ff:ff:ff:ff<br><br>
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000<br>
link/ether b8:27:eb:99:1e:d5 brd ff:ff:ff:ff:ff:ff<br><br>
4: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000<br>
link/ether be:90:ed:11:c1:07 brd ff:ff:ff:ff:ff:ff<br>
inet 169.254.2.14/16 brd 169.254.255.255 scope global wwan0<br>
inet6 fe80::2152:9df6:6360:27d1/64 scope link <br>
valid_lft forever preferred_lft forever<br><br></brodcast>
I hope this shows some good things. Thank you for the support!
Final edit:
@Ingo helped me to find the Problem. It was the Surfstick that caused it. I took another Surfstick with the same SIM Card and it worked. If somebody has the same problem try that out i hope it helps someone and it doesen t takes you 3 whole days to figure it out ^^.
