10
I have a client who has several large bronze signboards, each with 100-150 little light bulbs on it, totaling approximately 400 bulbs. The bulbs are turned on and off on a schedule, currently by hand (partially unscrewing the bulbs that are not needed). Most of the time, approximately a dozen bulbs will be illuminated at a time, though there are a few days every year that all 400 need to be on. The current bulbs are 120 volt AC, with the neutral connection made through the bronze frame of the board.
I want to replace all of the bulbs with LEDs to reduce power usage (and shock risk from touching the bronze board and a ground) and to schedule the turning on and off of the lights. I saw this question about controlling multiple LEDs, but it doesn't sound like that solution will scale to the hundreds of bulbs that I need, both because of the number of connections and chips needed and because of the current required (even though I usually only need a dozen or so lamps on at once; the few days that I need all of them at once will require a lot of current).
Does anyone have any ideas for how to do this? If I have to, I can control each of the boards (with 100-150 lamps) from a separate device, but I would prefer to do them all from one.
UPDATE: I should say that, although I have looked at several LED voltage/current options, I'm not committed to anything yet (and I haven't bought anything yet), so I can choose what I will get based on whatever fits best in this situation. The only requirement I have right now is that the LEDs must be orange, to match the color of the old bulbs (though they don't need to be exactly the same).
Moshe Katz
  • 582
Depending on the LEDs you are using, It may be possible to use a multiplexing scheme to reduce the number of drivers you need.
It's probably simpler to use a bunch of 4094 shift registers daisy chained. You can bitbang the clock/data or use the SPI hardware to drive them
Each 4094 can control 8 LEDs. You'll most likely need a small driver (eg transistor) per LED if you do it this way.
If there is a regular layout, you will save a lot of work (and opportunities for mistakes) by making a small PCB that can be tiled together.
John La Rooy
  • 12,005
  • 48
  • 77
There is some documentation available on Swarm Light, which a design installation featuring a large amount of individually controlled LEDs. They used 1 microcontroller for each set of 3 LEDs and six more to communicate with each of the 300 "sticks" of 10 controllers via serial interfaces. Perhaps your 400 LEDs are many enough to require such an architecture.
Bengt
  • 2,427
  • 22
  • 26
